Bluebaru
As I recently purchased a set of 245/70/16, Nokian Outpost nAT's and some 16x7 Method MR707 Bead grip wheels, purchased at close out price, I thought I'd compare them to my 245/65/17, Mickey Thompson Baja Boss A/T's.
The new wheels weigh just 17.7lbs and are 10lbs lighter each than the 17x7.5 Alpha Foxtrots and the Nokians weigh ~2.5lbs less than the Mickeys. 36.4lbs vs 39lbs, so I went in with some preconceived notions. I'll preface further comparison by saying the Mickeys are by no means worn out, as they are at~11/32" tread depth now and the Outpost's come with 14/32" vs the Mickey's 16/32". And as I have just one weekend of off road use, in the snow with both tires and a limited amount of Highway use with the Outpost's, ~375 miles, this is not as comprehensive as many would like.
All that said, the Outpost nAT's are noticeably better in the snow but not by a huge margin. The Mickey's tended to push out, a little, on some turns and the rear would step out a little, in some of the twisty bits, while the Outpost's never stepped out in the rear they did still push out some, in the front but less often than the Mickey's.
Road feel, noise and gas millage, that's where my preconceived notions seemed to have failed me? What I expected with the Outpost's/Method's reduced weight and 1/2" taller sidewalls was better gas mileage and a softer ride. I can't say definitively, with but the one weekend on the Outposts but it would seem just the opposite is true! On the Highway, small bumps seemed to have a sharper feel and I'm estimating my gas mileage is down about 1 mpg, on the interstate, based on my display. It certainly should be better in stop and go traffic, so this was a surprise, even if just based on highway use. The Outpost's are also louder than the Mickeys, when both are new and possibly even now when the Mickeys have worn down ~5/32", to ~11/32". The noise is also higher pitched, which I find less pleasant. Would any of these things keep me from recommending them to someone else, wanting a good 245/70/16, XL load rated tire, NO, because there just are not many in that size and they come with a good warranty and they are a little better in the snow and maybe a little cheaper but if you are looking for a 245/65/17 I think I'd look elsewhere unless the slightly better snow performance and maybe a little less cost and above average warranty were all super important, to you.
I'll also point out that the Outpost's are also offered in an XL load rated 235/70/16, if you are unwilling to push the limit on tire diameter. My 245's, un mounted measured 29.25" in diameter and mounted and aired to 33psi, 29.5" and in combination with the 16x7 +30 wheels, at full drop and full lock they only cleared the felt fender liner by a few sheets of paper, same at full bump.
Now I just need to do more testing and especially on some rough rocky terrain and mud where the Mickey's excel. pics coming soon.
Ford Bronco Sport Nokian Outpost nAT tires - initial review vs MT Baja Boss IMG_2621
Ford Bronco Sport Nokian Outpost nAT tires - initial review vs MT Baja Boss IMG_2623
Ford Bronco Sport Nokian Outpost nAT tires - initial review vs MT Baja Boss IMG_2645
Ford Bronco Sport Nokian Outpost nAT tires - initial review vs MT Baja Boss 1706213318911
Ford Bronco Sport Nokian Outpost nAT tires - initial review vs MT Baja Boss 1706213421586
Ford Bronco Sport Nokian Outpost nAT tires - initial review vs MT Baja Boss IMG_2639
I run 245 65 17 Falken Rubriteks on my Badlands and have brushed the felt wheel well liners with them.
Happy that you acknowledged that 245 65 17 tires have little to no clearance in certain situations. I have been saying that as well and some people think they can get away with running 70's series tires which isn't the case unless all you do is traverse parking lots.
I do like the idea of running 16" rims with the taller tire, I'll be looking into it when my Falkens wear out.
4Cast4living
Utah
Any updates on your experience with Nokian Outpost Nats? Also, are you still happy with your Flatout suspension?
Bluebaru
Bluebaru
Yes, I'm still happy with my Flatout GR+ Coilovers, though I do have some noise, from the right front, that my mechanic says is the shock, it self and has been checked 3+ times and the top mount replaced, with no improvement.
I now have 2,314 miles on My Nokian's and will be putting the Mickey's back on, some time this month and and run them until at least some time in the fall or possibly as late as 1/25. Tires are currently at 13/32, so not great mileage with either set of tires, maybe it's all the off-road use at reduced air pressure? They still make the same noise and ride is still worse but my gas mileage has improved and is now on par with the Mickey's. I never really got to test them in mud but did make several snow trips and while slightly better in light snow 2-5" they were nothing special in heavy or packed drifts but this could be a failure on my part as I failed to try either "Sand" or "Mud and Ruts" modes. They are holding up excellently when the sidewalls get pinched, Rock crawling, though I haven't quite tortured them as much as the Mickey's.
4Cast4living
Utah
Thank you for the updates! I'm a little over 40K miles and pretty much worn through two sets of tires now (oem wildpeaks, and now nomad grapplers) I too spend a lot of time in rough terrain with tires aired down so looking for my next set and leaning towards the nATs. I also want more ground clearance, but can't decide on spacer or coilover... also partly waiting to see if there are cv issues with a lift...
