No Data Link using scanner
Black Horse
Dave
SW Ohio
2021 Bronco Sport, 2009 F250, 1999 Mustang Cobra
Using an older, simple type code scanner - it reads the code just fine, but when I try to erase it keep getting a "No Data Link" message. Tried with power off, power on, and engine running - same issue. Never had this issue with any other vehicle. Any thoughts?
elvisimprsntr
Elvis
'25 BS BB
Older ELM327 scanners are likely not compatible with OBDII communication protocols in newer vehicle.
For example, modern ODBII readers can read both medium speed (MS) and high speed (HS) CAN bus.
These are compatible with https://forscan.org/ software for Windows, iOS, Android
Windows - Supports bi-directional controls, and module configuration and programming with the $20 extended license.
https://www.amazon.com/dp/B081VQVD3F
iOS/Android
https://www.amazon.com/dp/B07JFRFJG6
Another option are the Innova brand of scanners.
https://www.amazon.com/5610-Bidirectional-Lifetime-OE-Level-Functions/dp/B07Z481NJM
https://www.amazon.com/Innova-1000-OBD2-Scanner-Bluetooth/dp/B0D32BNNQ9
Black Horse
Dave
SW Ohio
Thank you. I'm surprised it read at all.
