NHTSA Closes Ford Bronco Sport, Maverick 12V Battery Investigation
Th 4+ year Battery saga has come to an end
(a second) recall (25S02) instructed dealers to replace the existing 12-volt battery with an AGM unit, a move that came after the automaker determined that the original battery – sourced from a supplier called Camel – contained internal manufacturing defects that could cause a loss of power.
Customers with vehicles equipped with a different 12-volt battery – from a supplier called Clarios – weren’t experiencing these types of issues when the first recall (24S24) rolled out either, but Ford later determined that those units were exhibiting the same failure mode as batteries from Camel.
In the meantime, Ford is still facing a lawsuit claiming that its fix for this particular issue is “wholly inadequate,” devalues the vehicles, and causes a “cognizable risk.”
Full article: https://fordauthority.com/2025/10/nhtsa-closes-ford-bronco-sport-maverick-12v-battery-investigation/
It makes me wonder if the "internal welding failures" claims were a ruse from Ford to make Camel shoulder the blame while all along it's just an inadequate power source type for the function of the system. I think the replacement was a satisfactory fix for my vehicle. I haven't had a deep sleep alert since it was replaced. The battery is about 4 years newer, so of course that might simply be the difference but it has solved the issue. I think that litigant will face an uphill battle.
