Sold: Ohio Need help with forscan regarding audio.
Xzavior1818
Anthony
Canton
So I replaced my door speakers with the Jbl gto29s (Highly recommend by the way) and it cleaned up the sound quite a bit. It's also louder and less muddy just on the bass. I'd say volume 22 sounds as loud as volume 25 with the factory speakers. So next I want to add a subwoofer and tweak the Eq of the system to flat. I want full range in the front and rears as well. I don't know why the rears were cutoff at 300hz when they are the same woofers as the front?
I know there's some info on the web on how to do this but it's so scattered across different forums and videos and nobody has directly followed up with experience that it works correctly.
Anyway I would like a direct answer as to the lines i need to adjust in forscan to :
1 : change the rears to full signal. (going to use the rears to run the audio signal to a sub)
2 : Eq settings to flat
Also, please let me know any issues you had after adjusting these, like does the factory radio distort at lower volumes and such.
Thanks!
Ford Bronco Sport Need help with forscan regarding audio. 20250303_105459
Greeno
Buffalo, NY
Did you ever get any answers for this or find a forum/group that typically has a lot of technical knowledge in it? Find myself guilty of finding and answer and not sharing though lol
Xzavior1818
Xzavior1818
Anthony
Canton
I found out how to tweak the eq to flat but the head unit itself starts to clip around volume 22. I plan to buy a kicker key and go that route just been lazy. Do you have any questions?
Greeno
Buffalo, NY
Was just curious if you ever found a way to get full signal to the rears you mentioned. Helping a friend with some audio on their Bronco Sport.
I've been content with the B&O.
