- First Name
- Mike
- Joined
- Nov 3, 2021
- Threads
- 6
- Messages
- 1,138
- Reaction score
- 1,713
- Location
- Calgary, AB
- Vehicle(s)
- 2022 Ford Bronco Sport
Thanks! It looks awesome!Just posted the bird to the thread MJE sent
Will do. Literally just dropped them off at the coater. All goes well, they should be ready to pick up on Monday.Can you please post a picture of the powder coated wheels, been debating it but I still think I want 17"
I talked to a number of shops in my area and they all quoted around $1100-1200 for the lift kit, 4/5hrs labor, and alignment.This is great! Thanks for posting.
So, what does a standard lift on the OB cost ballpark? I have been looking to get new tires (currently stock) for My OB but wondering if I should prioritize the lift instead?
One shop told me if I got the lift first and had the alignment done, then whenever I got new tires put on later, the alignment would still be good. Didn’t know if I trusted that and felt more comfortable getting it all done at once, fwiwwondering if I should prioritize the lift instead?
Whether the alignment is done with the lift or soon after, it should not affect when the alignment needs to be done again. New tires should not require an alignment. However, it is a good time to have it done in case alignment issues are causing uneven tire wear. You can check that with the old tires and then decide if you need to get an alignment. Any tire shop/person worth a damn should be doing that for you when they replace the tires and letting you know there is uneven wear.One shop told me if I got the lift first and had the alignment done, then whenever I got new tires put on later, the alignment would still be good. Didn’t know if I trusted that and felt more comfortable getting it all done at once, fwiw
Same here, pretty much just the daily commute so far, but looking forward to hitting the beach/trails this spring/summer!Oh man, we have such similar stories! My car was an 09 escape hybrid for two years before we were able to snag a BS OB trim. I am in love with it! I wish I had more opportunities to drive it, honestly. Just to work and back so far.
