Must be a USB thing then. Mine comes back ever time to where it was when it was shut off but I never have tried the USB port yet for music.No car play. I leave the usb plugged in
You aren't alone. I have a USB in all the time and it's pretty annoying. I think it is trying to get to the USB first but then about half the time I get the message that it is unable to connect to the Media Device and the radio comes on. The USB is then available as a Source 15 seconds later and I select it.No car play. I leave the usb plugged in
Most people solve that problem by removing any SiriusXM stations that someone might have programmed in before you received your bronco sport.It defaults to satellite. Is annoying af. I don’t use it and it isn’t activated so I get the initial pop up that it’s expired. Close out of that and another pops up with the radio id and xm phone number. Cannot even use the screen or select another source until you close out of those. Has done this since new. I use USB all the time also. Is just the way it setup. Almost everything is based around satellite in these, even the shitty amp dsp is xm bias towards the sound profiles
