Low beam headlights seem to aimed too low
21BRNCO-SPORT
Macomb, MI
I noticed my low beam headlights are aimed a bit low . At first I thought it was just me but then a few passengers said the same thing . Does anyone know how to adjust them? I tried the owners manual with no luck .
Bronclahoma
Oklahoma
I doubt they are aimed low. Many new vehicles have the low beams filtered so they don't blind oncoming traffic. There will be a clear line at the top of their beams and dark above it. If that is the case, this is normal.
Be sure you have your auto dimmer turned on so you will be using the brights when safe to do so.
I've never seen headlight aim adjustments in a car owner's manual; you usually have to take it to a shop.
EDIT: I'll be damned; MoFoCo just made a liar out of me (see post below). Maybe I should look at the Owner's Manual before I start typing!
You might consider checking them based on more than just a hunch. Here's a good video on how to do that:
Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
MaxVelocity
Montana
1970 Bronco
I would have the dealer check them. Body shops would also typically be able to aim headlights but with this vehicle being so new that might not yet be the case.
MoFoCo
Mayor's Income, TN
I think mine are aimed a bit high, and with some squat it’s way too high. Had a weekend’s worth of luggage, family of 4 and 2 bikes on the hitch rack, a lot of oncoming drivers flashed at me like the high beams were on.
Looks like adjustment is very easy, it’s detailed in the Owner’s Manual page 284.
https://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?variantid=7450&languageCode=en&countryCode=USA&Uid=G2088526&ProcUid=G2121516&userMarket=usa&div=f&vFilteringEnabled=False
vzepol
Victor
The sharp cutoff is deceptive. I set the lights on auto and was surprised at how well the lights adjust to the conditions.
21BRNCO-SPORT
21BRNCO-SPORT
Macomb, MI
Thanks , I will try this next weekend. Will let you know if it did or did not need adjustment .
