You adjust the settings using the Infotainment system, there is an option to disable Proximity sensor, allow only the drivers door or all doors to be opened, (I have it set to unlock the drivers door, once the drivers door is opened a bit the others will unlock)Do all of the doors on the BS have keyless entry sensors? Or is it just the front doors?
When the car is locked and you go to open a rear door with the key on you, does it unlock?You adjust the settings using the Infotainment system, there is an option to disable Proximity sensor, allow only the drivers door or all doors to be opened, (I have it set to unlock the drivers door, once the drivers door is opened a bit the others will unlock)
Not the rear doors. Sensors are on front doors and liftgate.When the car is locked and you go to open a rear door with the key on you, does it unlock?
Thanks....would have been nice to have the sensors on all 4, but it's not a huge deal.Not the rear doors. Sensors are on front doors and liftgate.
Would you mind explaining how to get to that setting? Is it in Setting > Vehicle?You adjust the settings using the Infotainment system, there is an option to disable Proximity sensor, allow only the drivers door or all doors to be opened, (I have it set to unlock the drivers door, once the drivers door is opened a bit the others will unlock)
I experienced this issue today. I could have sworn I could unlock the lift gate with my key in my pocket/in close proximity but then all of a sudden, I can no longer do it. Curiously, I can unlock and open the glass...Is anyone having a problem with the lift gate not unlocking. I was sure it used to unlock without having to get my key out and press the button but now I have to unlock it first to open it. The front doors still work when I have the key on me but the lift gate doesn’t anymore. The taillights just blink when go to open it.
Settings > vehicle settings > locksWould you mind explaining how to get to that setting? Is it in Setting > Vehicle?
Ok glad I'm not the only one. I wish they had left that feature, I liked it. I wonder if there is a way to reverse this? To get that feature back?Same issue here. Have had the BS since end of December, never had to press the unlock button for the liftgate. Now I do. I assumed they pushed out an over the air update or something.
I'll have to go try the glass. That's interestingI experienced this issue today. I could have sworn I could unlock the lift gate with my key in my pocket/in close proximity but then all of a sudden, I can no longer do it. Curiously, I can unlock and open the glass...
Without taking this off-topic, when they push out updates OTA, does the BS have to be connected to WiFi? As far I know, my BS never has because I had issues connecting to my home WiFi. I looked into it and it's a SYNC quirk (even though I never had an issue with my F-150).I assumed they pushed out an over the air update or something.
Ever trying connecting to WiFi elsewhere? But...my understanding (could be wrong) is that FordPass Connect over 4G is FREE and supports all of these related operations (OTA updates, limited remote starts, etc.?)? And the same over WiFi as you would -- should be able to access at home or elsewhere. I wonder what the SYNC3 problem with you WiFi is? AFAIK the PAID FordPass Connect service is only for the WiFi hotspot feature?Without taking this off-topic, when they push out updates OTA, does the BS have to be connected to WiFi? As far I know, my BS never has because I had issues connecting to my home WiFi. I looked into it and it's a SYNC quirk (even though I never had an issue with my F-150).
So I guess what I'm saying is if being connected to WiFi IS a requirement to get the update, then that's not the case for me since I would have never gotten the update.
I have not tried connecting WiFi elsewhere, but you may be right about OTA updates being performed using 4G LTE. I also think these updates can be performed via WiFi, or at least it seemed like an option in my '17 F-150. I did find this article that seems to confirm wireless OTA updates on newer vehicles (2020+):Ever trying connecting to WiFi elsewhere? But...my understanding (could be wrong) is that FordPass Connect over 4G is FREE and supports all of these related operations (OTA updates, limited remote starts, etc.?)? And the same over WiFi as you would -- should be able to access at home or elsewhere. I wonder what the SYNC3 problem with you WiFi is? AFAIK the PAID FordPass Connect service is only for the WiFi hotspot feature?
