Interior Light Issue
BroncoSportBB_Socal
Mace
LOS ANGELES
So about 3 days ago, I'd notice that the interior lights weren't turning off when I walked away from the car. I checked the switch and it is on "door mode". So they should turn off if the doors are closed. I tried again and none of the dome lights turn off.. I then switched it to "off mode" it does turn off. I'm guessing a sensor or some sort.
Has anyone experienced this issue?
johnardsg
johnard
2021 BS BigBend/2011 v6 Rav4
Yes, ive seen it on my bigbend…theres a delay before lights turn off. Also another scenario is that the dome lights switch off after you lock the car in like 10-15sec. it behaves like the park lights of the car, they turn off at the same time after locking.
Fossil
Ernie
ohio
Raptor, SVT Mustang, SHO,
try double clicking the fob lock button, if you get a single horn beep all is good, a double beep indicates a door sensor is showing as open.
generally on Fords a double push will kill the interior and exterior lights instantly with the exception of the headlight off delay.
Advertisement
Advertisement
