Installed lights to factory nudge bar
sdilecce
Sam
Saskatchewan
2026 Bronco Sport
Ford Bronco Sport Installed lights to factory nudge bar IMG_6335
I just mounted a pair of BiglionX 5 inch spot/flood light to my nudge bar using modified KC brackets. I used the fused, relay harness that came with the lights but removed the switch and connected the trigger wire to the Aux 2 switch wire. I am happy with how it turned out and these lights are very nice.
jlpskydive
J.
Satellite Beach, Fl.
25 Badlands, Sasquatch, Oxford White
In addition to the questions above, which brackets and where‘s the wire for aux2? If I’m understanding it right, you’re only using that wire as an on/off signal and the power is routed to the battery????
Looks great!
sdilecce
Sam
Saskatchewan
2026 Bronco Sport
No sensors blocked. The big Bend doesnt have a front camera. I used KC 2inch tube mount brackets but had to modify them by cutting off the protruding part and drill and tapping an M10 hole in the bottom. I hooked up the harness to the battery, and connected the blue wire that was to the switch to the Aux 2 wire wich comes taped to the harness below the underhood fusebox.
