In Stock! New RIVAL Hood Lifts
Status
Not open for further replies.
RIVAL 4x4
Diamond Sponsor
Houston, TX
rival4x4usa.com
Now In Stock!
No-drill, bolt-on installation.
High quality Stabilus (Germany) gas struts which are used by vehicle manufacturers.
Precision designed hood lift kit specifically developed to suit the Bronco Sport factory hood. Mounts to factory fitting points with the fasteners supplied.
Make it easy to lift your hood and hold it in that position giving you a clear and safe path to any maintenance in the engine.
This kit includes everything you need for a successful installation.
Works perfectly in conditions from -20F to 170F.
Lifetime warranty.
Ford Bronco Sport In Stock! New RIVAL Hood Lifts 2A.ST.1807.1_Ford Bronco Sport_1
Ford Bronco Sport In Stock! New RIVAL Hood Lifts 2A.ST.1807.1_Ford Bronco Sport_2
Ford Bronco Sport In Stock! New RIVAL Hood Lifts 2A.ST.1807.1_Ford Bronco Sport_3
Ford Bronco Sport In Stock! New RIVAL Hood Lifts 2A.ST.1807.1_Ford Bronco Sport_4
jazzdab
Thom
Raleigh, NC
Is the tension adjustable such that it is not nigh impossible to shut the hood? Asking for an owner of Redline Racing struts ...
RIVAL 4x4
RIVAL 4x4
Diamond Sponsor
Houston, TX
rival4x4usa.com
No, they are not adjustable, but the very struts were designed individually for this geometry of the hood and its weight. We have added the video to the gallery showing the opening: Product gallery
I think the concern is closing. Without the struts you can simply drop the hood from 8-10 inches and it will close. With the struts, you have to push down on the hood as it's closing, which introduces the possibility of putting a dent in the hood.
For those of you with struts, you can minimize the possibility of denting your hood by keeping the palm of your hand flat and centered on the part of the hood where the sheet metal is bent, where it's strongest and least likely to dent. See video below.
https://www.broncosportforum.com/forum/data/video/24/24791-fa7b322b9df44fe467229adc37bfc97f.mp4
jazzdab
Thom
Raleigh, NC
I worry more about service people being overly aggressive. My dad had a van with "dealer installed dents" that he went round and round with the dealer on for at least a year before giving up and trading the vehicle for another brand.
That too. I do almost all of my own service work, so that's less of a concern for me. If you're really concerned about it make sure to mention your car has struts to the service rep when you check your car in. Tell them that closing the hood by pushing down on top will cause dents (they should already know this). Make sure you show them prior to releasing the car to their car that your hood is not dented. Take a photo.
Status
