the push/pull lock is a mechanical lock and several hours ago I deleted and modified several of my posts including the one you quoted - that specific post was incorrect so I deleted it (or modified it I donāt remember)Dude
I believe the push/pull lock is a mechanical lock so the software settings do not apply, but I may well be wrong!
Could you please try the following to see if your vehicle responds differently than mine?
1) If you don't have an external keypad, open your driver's side window so you can't lock yourself out.
2) Place your fob in the car.
3) Open the driver's door.
4) Press the push/pull lever into the flat/locked position.
5) Close the door.
6) Check if the push/pull lock is still flat.
7) Try to open the door without another fob on you or using the external keypad.
Could you please let me know if your vehicle unlocks the push/pull lock when you close the door?
Thanks,
Earlier today I followed your listed steps before I saw them - the only difference is all of my doors unlock as described in the owners manual so when the drivers door was locked with the keyfob inside the vehicle, I had 3 other doors to get into the vehicle
And I have the external keypad, and Ford App on my phone so I could get in those ways as well which are unavailable in your case bc your 2025 doesnāt have the external keypad and your daughter locks her phone in the car
Itās a great lesson for your daughter and perhaps she will stop locking both her phone and keyfob in the vehicle. Or not.
Glad you figured out a solution and did not involve any cost
