Morning all, curious if any motorheads have the same high idle duration on their 1.5 BS as do. If I leave my engine off for 10 minutes and restart the cold start idle programming kicks in, the duration is for approx. 30 to 60 seconds at 15-1800 rpm. Not an issue if I restart under 10 minutes of being off. The engine normally idles at or below around 900 normally.
Now I understand the sensors need to register adequate temperature and oil pressure before signaling the high idle dashpot (old school terminolgy) to disengage. Now days its more of a electro/mechanical/programming action than purely a mechanical action.
I'm one to always wait till low idle before engaging the transmission. It's a small issue but sometimes that 60 seconds of waiting for the rpms to drop below 1000 seems like 5 minutes. Just curious if anyone noticed this and if it's common across the board, if so than its baked into the programming. If not I'm curious if the idle idle dration can be adjusted.
