Help! Towing my BS from low clearance parking garage
HotChicken
Josh
Washington, DC
Electrical system is freaking out and my BS BB won’t start or turn over. Can’t even put it into neutral. I’m in a 7 foot clearance parking garage. Any tips or look outs for getting this thing towed without ruining the drive train??
Rinzler
Philly
If you haven’t done it already, check the owners manual on how to engage neutral or you can search here as it’s come up in previous threads. Hoping the system freak out doesn’t prevent you getting into neutral but it can be done w/o power on.
good luck
HotChicken
HotChicken
Josh
Washington, DC
Thanks. Still waiting on truck. It’s been a garbage day.
The issue is my 2001 BS won’t start with no prior warning. Full accessory power mode works but when I press on, the headlights, interior lights, all the dash lights, and the alternator (I think, ant least, it’s a clicking inside the hood somewhere) all turn on in unison about ten times. The engine doesn’t even try to turn over. Then nothing, except for “Park break fault service now”.
Anyone have any experience with this?
Lots of owners had a similar experience - not sure if you already bought a new AGM Battery and installed it yourself?
Stircrazy
BC, Canada
2023 Bronco sport
measure your battery voltage and see what it is. might be as simple as needing a jump to get it out then a new battery after if that was the issue
RS1
Ralph
Boston
2021 big bend. Happened to me luckily in my driveway. Original battery died. As to getting into neutral????? Sorry.
Dadio
Rob
Cobourg, Ontario
2023 Ford Bronco Sport
If you haven’t replaced your battery yet, and yours is a 2021 … then suggest to do it now anyway as it’s probably reached its lifespan. Strange electrical behaviors and non starting are most likely related to battery charge.
BabyBen
Spring Hill, FL
Two things to consider.
1. Read the Transmission section of the Manual(mine is page 168) to disengge the "manual park release cable" for towing. Read manual first. Prevents ruining the tranny while towing.
2. Last time my battery freaked out I bought a NOCO boost after battery replacement. I don't ever leave home without it. It will start your car so you can drive to the dealer to get the battery replaced. When your battery gets low the computer shuts down some of the systems usually with warnings. If you ignore the warnings and don't have your system checked immediately your vehicle will probably stop soon.
ATLAS BLUE BADLANDS
PNW
2024 BADLANDS
Parking garage? How long was it parked? How old is the battery?
