Heads up for possible recall on water pumps
Voodoo
drew
SC
24 Bronco Sport
I have a 24 BS Outerbanks and recently took it in for a service and the tech said we had hardly any coolant and that we had a leak. Fast forward to today when I picked it up and they said they had to replace the water pump and that they are seeing alot of the newer BS with this issue.
tconstan
Garnet Valley, PA
I, too, had the water pump replaced in my '22 BSOB!
Troiano27
Jeff
Nashville
2024 Bronco Sport
2 weeks ago took my 2024 in for oil change and tire rotation (roughly 26,000 miles). Was told I had a slight coolant leak and I should keep an eye on it. I asked if it was a warranty repair. Was told it was. So told them to keep it until it was fixed. Day later and I had it back. Water pump replaced.
love my BS Outerbanks. But drive a lot of miles. So, shortly after buying, I purchased the ford extended warranty for up to 175k or 6 years. With the max care (or whatever the highest is called). Next month I’ll have had her 1 year and will be at almost 29,000 miles.
Stircrazy
BC, Canada
2023 Bronco sport
did the leaks just skip the 23 models ? I though they had that issue fixed?
ELCouz
Canuckistan
Water pumps on the 1.5L are basically a disposable product
Dealers need to flush which a lot don't ... there is residual casting sand in the 1.5L block castings. It's eating the water pump, it is very abrasive.
I think this was included in TSB procedure, some technician don't check thoroughly unfortunately.
Black Rob
South Carolina
They flushed ours… Still leaked again.
Dannyp56
Danny
Payson, AZ
2024 Ford Bronco Sport
I have a 2024 BS OB I bought last June and don't even have 4000 miles on it yet. Just turned 3200.
If the problem with the 1.5L water pumps was due to “casting sand” don’t you think Ford would have fixed that by now? Think about it.
ELCouz
Canuckistan
That was one of the TSB ... ?‍♂
