Anyone see an issue when filling, the weight of the gas nozzle flexes the filler tube down causing the nozzle to keep punching off? I have to manually hold the nozzle up.
Correct. I do that too.I'm not sure it's a problem with flexing of the filler tube. I think it might be more of an issue with a narrowing of the tube at the anti-syphon valve. If you pull the pump handle out about an inch or so it should run fine without you having to hold it up.
Disguise yourself Bucko. Ring cameras are everywhereI'll try that the next time I'm siphoning gas from my neighbors car and adding to my tank at my weekly midnight runs.
Thanks! It's Halloween tonight; easy to wear a disguise.Disguise yourself Bucko. Ring cameras are everywhere
Don't need you absent from this forum..
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.Anyone see an issue when filling, the weight of the gas nozzle flexes the filler tube down causing the nozzle to keep punching off? I have to manually hold the nozzle up.
