With only 9 thousand made I believe so hard to spot one in the wild. The only trim level you should get TO BE HONEST! So far I see all the other trim levels are having problems.
Thank you for the correctionOnly 2000 of the Bronco Sport First Edition....
2000 for sureThank you for the correction
Knock on wood, I'm 3500 in and the Badlands has been flawless. It happens. Some vehicles just have issues, some design flaws take time to shake out. It's a first run vehicle. It's not the escape contrary to misconception and lazy sentiments. It's still a new configuration.With only 9 thousand made I believe so hard to spot one in the wild. The only trim level you should get TO BE HONEST! So far I see all the other trim levels are having problems.
This is the one I passed on earlier in March after initially putting the deposit down. Timing was off among other things. Another reason was I just wanted Badlands instead. It does look good though.With only 9 thousand made I believe so hard to spot one in the wild. The only trim level you should get TO BE HONEST! So far I see all the other trim levels are having problems.
That's how it played out for me too. Almost pulled a plug on it but at the end of the day I wanted those extra features. I wouldn't lie there is certain allure to owning FE though."only trim level to get"
Made me chuckle. I didn't feel like sacrificing features over a limited edition release. I know me and I would've traded it up after learning it didn't have everything the Badlands +PKG did.
That cactus gray looks white..I like itThis is the one I passed on earlier in March after initially putting the deposit down. Timing was off among other things. Another reason was I just wanted Badlands instead. It does look good though.
I see one every day on my way to hike. Because I'm driving it No problems yet @6k miles. Save the cracked windshield (rock chip) that took 2 months to get replaced. Love it!With only 9 thousand made I believe so hard to spot one in the wild. The only trim level you should get TO BE HONEST! So far I see all the other trim levels are having problems.
