Drive belt tearing
Hdscreens
Will
Baby bronco
Have been hearing squeaking from drive belt or pulleys so had to check under hood. Commented on coolant having to be filled for 2nd time that I’ve noticed but also noticed drive belt seems to be tearing. I sprayed a little lube to calm down squeaks for the time being. Anyone else had the same issue and it’s possible I might have water pump issue I’ve read in here.
Ford Bronco Sport Drive belt tearing 58F3C0DA-1116-4EE7-8DC5-590926ABD9E4
Ford Bronco Sport Drive belt tearing 289BE3C6-6B30-4A9B-A988-47F421CCC3ED
fourthgear
florida
That looks more like something hit & damaged the Pully"(s) & the Belt .
Whatheheck
Ken
Houston, TX
21 Bronco sport, 21Mustang GT
Yeah, not a water pump problem, it to the shop ASAP !
what is that glossy stuff on the belt ?
Hdscreens
Will
Baby bronco
It was fresh lubricant sprayed to calm the squeaky noise. I should take to dealer asap but it’s only vehicle I have at the moment. Tried to purchase a 2nd vehicle but out of 20 inquiries only got 2 responses.
AllTerrain
S
Ca
What's up with the situation?
Hdscreens
Will
Baby bronco
It’s gotten noisier like hamsters on a wheel but it’s still going. Coolant has gone down again after refill last week. I may drop it off at service Tuesday or Wednesday before I get stranded somewhere.
Hi there! Send a private message to us with your VIN and the name and location of your Ford dealership, along with some more details about your situation. I’d be happy to look into this for you. Thanks!
Hdscreens
Will
Baby bronco
It was indeed water pump failure which also caused the v-band to start tearing. Vehicle spent a week in service and got back today. Not too bad considering I thought the water pump backorder would have me waiting several weeks. Possible, Ford reps from these forums helped speed up process but either way thankful for them getting involved.
fourthgear
florida
So what looks like damage on the Pulley(s) is from the Belt ? Or didn't they explain anything on how a water pump failure would cause what looks like someone took a grinder to the Pulleys . Just curious .
Hdscreens
Will
Baby bronco
On pic the pulley seems damaged but it actually wasn’t. Pic is blurry but I went back to triple check on that but the loose threads from belt were simply making the pulley seem damaged on pic.
fourthgear
florida
OK , thats a good thing .
