Anyone else have their moonroof start creaking? Originally thought it was happening more in cold weather, but seems to be more constant now. Can hear it creak/rattle going over any uneven surface.
Yeah I have only greased mine once couple years back. But I used Dielectric grease cause that is what I had lying around at the time. But now have a tube of the high dollar synthetic lube on hand if it makes the noise again.Same thing on my 2018 F150.....I used Vaseline and put it on the entire rubber gasket around the glass......apply liberally and wipe off excess later....never made a noise since
Actually, the dielectric grease was probably ideal as it is typically a silicone grease, which is what the Honda product I mentioned is. I suspect that it is probably better for the seal than Vaseline.Yeah I have only greased mine once couple years back. But I used Dielectric grease cause that is what I had lying around at the time. But now have a tube of the high dollar synthetic lube on hand if it makes the noise again.
I thought dirt sticks to grease and Vaseline.Yeah I have only greased mine once couple years back. But I used Dielectric grease cause that is what I had lying around at the time. But now have a tube of the high dollar synthetic lube on hand if it makes the noise again.
