Climate Control and Radio Station?
stcornish
St. Louis
My new 2025 BSBD Sasquatch has the dual control climate control. The AC is turned on when the car is started even though it was off when the car was shut off. It doesn’t matter the outdoor temperature and it is not turned to auto. I looked through the owners manual but it doesn’t help. Any idea why it does this?
Also the radio changes stations by itself occasionally. It might be on a Sirius channel and change to an AM station or from an FM to a different FM station. I am definitely not touching the screen. Any ideas why?
Oh oh … those are shades of Sync 3.4 issues but you have Sync 4 so completely unrelated
On your AC, I believe you have it set to “Auto” even though you stated you don’t have auto set. Maybe try enabling Auto then disable Auto again.
Have you tried to google with “Sync 4” in quotes and added some text of the issues you are having (not in quotes) to see if you can find solutions to those issues?
My new 2025 BSBD Sasquatch …
Are you possibly touching the up/down tune buttons on the steering wheel?
Serge
Sergio
HI ! I have a BS Bandlands 2025, and have the same issue with the AA. Also I put it off manually and later go on again (and the light continue off )
You can solve this issue ?
Stircrazy
BC, Canada
2023 Bronco sport
it probably defaults to a setting that includes defrost, so the ac will automaticly be enguaged as defrost dryes the air out which speeds the clearing of windows.
