Check engine light with code U034B after recall for battery replacement and software update 2021 Big Bend
Susanne Smith
Susanne
Morton, WA
Ever since the recall for a new battery and software update on our 2021 Bronco Sport Big Bend, we have been getting check engine light with code U034B popping up. Took it to dealer and they could not identify any problem. This issue seems to only be happening after going over bumpy areas (i.e. railroad tracks, rumble strips, etc.) Vehicle went into limp mode one time and after about 20 minutes was able to restart and limp mode was gone. Anyone else had this type of problem and/or been able to resolve the issue. Thank You
2025 Badlands Sasquatch
Could just be a loose battery terminal connection. That it happened after a battery replacement and only occurs when encountering bumps lends me to think that's the most likely cause. The U034B can be triggered by bad connections even though it's not directly pointing to the source fault.
Susanne Smith
Susanne
Morton, WA
Susanne Smith
Susanne
Morton, WA
I had a suspicion that this might be a problem so made sure all of the battery connections were tight. U034B popped up again. Could it possibly be a bad ground connection in the AWD module? Thanks for your response.
I’d have the battery tested. I know it’s new, but that’s no guarantee of performance. Could also be an internal defect in manufacture.
Bad grounds seem to also be a recurring theme.
Susanne Smith
Susanne
Morton, WA
Susanne Smith
Susanne
Morton, WA
After a diagnostic and battery test, battery tested good and diagnostic, tech says they think problem is gone, but drive it over the weekend and see. Well, first a warning square and bells saying service transmission but no cel. Next day, same warning with cel. Dtc's exactly the same as before, all U codes. New deep dive diagnostic and battery test. Dealer inform us that intermittent short found in PCM, visible water damage. Needs replacement to the tune of $2,000. Wish us luck. To be done on Tuesday.
You already received an answer from the dealer of what the issue is.
Here is a list of associated codes.
These codes are commonly diagnosed with error code U034B. As your initial code did not contain any details
  • P1624 [2] SBDS Interactive Codes
Sub-Codes From Detailed OBD Scanners
Sub-CodeGeneral MeaningPossible CausesDiagnostic Steps
U034B-00 / U034B00No Failure DetailsN/ANo further information.
U034B-01 / U034B01Short to Battery VoltageWiring harness shorted to battery voltage, faulty component, damaged connector.Inspect wiring for shorts to power, check connectors for damage, test component functionality.
U034B-02 / U034B02Short to GroundWiring harness shorted to ground, damaged component, faulty insulation.Inspect wiring for shorts to ground, check component grounds, repair damaged insulation.
U034B-03 / U034B03Low VoltageWeak battery, poor charging system, voltage drop due to resistance in wiring.Test battery voltage, inspect alternator output, check for voltage drops in wiring.
U034B-04 / U034B04Open CircuitBroken wire, disconnected connector, failed component.Inspect wiring for breaks, ensure all connectors are properly seated, test component continuity.
U034B-05 / U034B05Short Circuit Between WiresInsulation damage causing wires to touch, incorrect wiring repairs.Inspect wiring harness for damage, repair or replace faulty wiring.
U034B-06 / U034B06Short to Positive (Other than Battery)Wiring shorted to another positive voltage source.Trace wiring to identify unintended voltage sources, isolate and repair wiring.
U034B-07 / U034B07Short to NegativeWiring shorted to negative terminal or ground.Inspect wiring for contact with ground points, repair insulation.
U034B-08 / U034B08Component FaultDefective component, internal failure.Test component operation, replace if necessary.
U034B-09 / U034B09Sensor FaultFaulty sensor, sensor out of range.Test sensor readings, compare to specifications, replace if faulty.
U034B-0A / U034B0ACircuit IntermittentLoose connections, intermittent wiring faults.Inspect connectors and wiring for intermittent issues, perform wiggle test.
U034B-0B / U034B0BCircuit Voltage HighOvercharging system, faulty voltage regulator.Test system voltage levels, inspect voltage regulator and alternator.
U034B-0C / U034B0CCircuit Voltage LowUndercharging system, excessive voltage drop.Check battery health, inspect charging system, test for voltage drops.
U034B-0D / U034B0DHigh ResistanceCorroded connectors, damaged wiring, loose connections.Inspect and clean connectors, check wiring resistance, tighten any loose connections.
U034B-0E / U034B0ELow ResistanceShorted wires, internal component short, contamination causing short.Inspect wiring for shorts, test component resistance, clean any contaminants.
U034B-0F / U034B0FCommunication ErrorFaulty communication bus, unresponsive module, wiring issues.Check communication bus integrity, verify module operation, inspect wiring and connectors.
U034B-10 / U034B10Invalid Data ReceivedFaulty sensor sending incorrect data, software glitch, interference.Test sensor output, update/reflash software, check for electrical interference.
U034B-11 / U034B11Ground FaultPoor grounding, corroded ground connections.Inspect ground connections, clean and secure as necessary.
U034B-12 / U034B12Control Module FaultDefective control module, internal errors.Perform module self-test, reprogram or replace module if faulty.
U034B-13 / U034B13Sensor Not CalibratedSensor installation without calibration, sensor drift.Calibrate the sensor per manufacturer guidelines, replace if calibration fails.
U034B-14 / U034B14Component Not ProgrammedNew component requires programming, software mismatch.Program the component using appropriate diagnostic equipment.
U034B-15 / U034B15Calibration ErrorIncorrect calibration data, corrupted calibration files.Recalibrate system, update software if necessary.
U034B-16 / U034B16Incorrect Component InstalledWrong part number, incompatible component.Verify part numbers, replace with correct component.
U034B-17 / U034B17Power Supply ErrorInterruption in power supply, fuse blown, relay failure.Check fuses and relays, test for proper voltage supply.
U034B-18 / U034B18Overcurrent ConditionShort circuit causing high current, faulty component drawing excessive current.Inspect for shorts, measure current draw, replace faulty components.
U034B-19 / U034B19Data Bus ErrorFaulty communication lines, bus contention, module malfunction.Inspect bus wiring, check for conflicting modules, use oscilloscope for signal integrity.
U034B-1A / U034B1ARedundant Sensor ErrorDiscrepancy between primary and secondary sensors.Compare sensor outputs, replace faulty sensor.
U034B-1B / U034B1BMechanical Failure DetectedPhysical damage, wear and tear, mechanical obstruction.Perform visual inspection, test mechanical components, repair or replace as needed.
U034B-1C / U034B1CActuator MalfunctionFaulty actuator, stuck mechanism.Test actuator operation, inspect for mechanical binding, replace if necessary.
U034B-1D / U034B1DSignal ImplausibleSensor signal out of expected range, faulty readings.Verify sensor signals, compare with known good values, replace sensor if faulty.
U034B-1E / U034B1EThermistor ErrorFaulty temperature sensor, wiring issues.Test thermistor resistance, inspect wiring, replace if defective.
U034B-1F / U034B1FConfiguration ErrorIncorrect settings, software configuration mismatch.Check configuration settings, update software, reconfigure as per specifications.
Susanne Smith
Susanne
Morton, WA
Thank You for this information Robert. When I found out where the PCM is located on the 21 Big Bend, I am surprised that this isn't a large problem for many owners of this model.
You may be referring to the control module located on the drivers side front fender area above the wheel well liner
the modules located there along with several connectors can experience water intrusion especially when submerged under water for a long enough period of time
I would guess your 2021 experienced water intrusion sometime in its lifetime
https://www.broncosportforum.com/forum/threads/battery-charging-problem-2-293.2189/post-40595
Susanne Smith
Susanne
Morton, WA
Yes, that is where the module is located. Vehicle has never been submerged in any way, but we do live in Western Washington close to the Cascades. The saying is, 'we don't tan, we rust.' 😁
One of the threads on this forum for a 2021 like yours stated the connectors on that module were damaged by moisture - vehicle was only a couple months old and never in any water - the post stated was a factory issue
