Buzzing from rear of car after new RDU installed - dealer doesn’t know why
brandim
Brandi
2022 Bronco Sport Big Bend
A month ago I had a brand new RDU installed after I was having a grinding when turning sharp. After that repair, I started hearing a loud buzzing noise from the rear of my car anytime I’m above 35mph. It’s a constant noise regardless of acceleration, turning, etc. I took it back and they claimed it was a bent heat shield, but it still made the noise. Took it back a second time and they continue to claim it’s not an RDU issue even though that’s when I started hearing the noise. I found on Reddit the idea to turn off traction control and when I do that, th noise immediately stops like flipping a switch. The dealer looked at it again and now they’re saying it could be a brake issue, but they’ll start charging me to look into it further. My car has about 59k miles on it. Anyone had this same issue and figured out the problem? I’m fine turning off the traction control to avoid the noise but if there’s a serious issue I don’t want to keep driving on it and making it worse.
Chiefthepup
Colt
Washington
Per chat gpt so take it with a grain of salt
On a Bronco Sport, a buzzing or humming from the rear that stops when you turn traction control off is almost always normal operation of the traction/ABS system, not a failing differential.
Here’s what’s going on 👇
What’s actually making the noise
Your Bronco Sport uses brake-based traction control + an electronically controlled rear drive unit (RDU).
When traction control is ON, the system:
  • Pulses the rear brakes to stop wheel slip
  • Engages/disengages the rear clutch pack
  • Uses the ABS pump to modulate pressure
That pulsing creates a:
  • Buzzing
  • Grinding
  • Electric “whirr” or vibration
When you turn traction control OFF, those brake pulses stop → noise disappears.
When it happens most
This is especially common during:
  • Slow turns in parking lots
  • Tight U-turns
  • Wet pavement
  • Gravel or uneven surfaces
  • Light throttle while turning
Ford’s AWD tuning is very aggressive, so the system intervenes early.
This is considered NORMAL if:
✅ No warning lights
✅ No clunks or bangs
✅ Noise only happens while moving/turning
✅ Noise stops when traction control is off
Many Bronco Sport owners report the exact same thing.
When it might NOT be normal
Get it checked if you notice:
  • Loud metal clunks
  • Noise even while driving straight
  • Vibration at highway speed
  • Burning smell
  • AWD / ABS warning lights
Those could point to:
  • Rear drive unit fluid issue
  • Wheel bearing
  • Faulty ABS sensor
What you can do
  • Leave it alone if it’s mild (most do)
  • Turn TC off temporarily in parking lots
  • At next service, ask them to:
    • Check rear drive unit fluid
    • Check for ABS/traction control updates
Bottom line
Nothing is “breaking.”
You’re hearing the traction control system actively working — and turning it off proves that’s the source.
Ernest T
Dennis
Central Texas
A noise that wasn’t there before a part was changed is a giant red flag. Stopping when you turn something off. Is another. I’d hound my dealer and/or elevate the issue to Ford.
Whpony96
Scott
Nampa, Idaho
I can tell you this our 2025 Bronco Sport Badlands doe not make that sound. Nor has it ever. It's 100% NOT Normal! It didn't make it before then it's NOT RIGHT. Not all techs are created equal. I'll bet that was the techs first RDU and when he tore it apart he did a "opsie". Understand you can go to any Ford service authorized shop. They do not have to be a Ford dealership. One of the best out there is Brian @ FordTechMakuloco people send him their vehicles from all over the nation to get worked in. https://www.youtube.com/user/FordTechMakuloco That said I would highly recommend going to a new shop to have it looked at.
fjbear!
sam
mississippi
2024 bronco sport
Go to a better dealer before warranty is up. They put a used one in i bet
