Do you have your order number? That is key to getting your information. On my order summary from my dealer, the number you need is called an Order Code (mine was 4 digits). When you have that, you can go to Ford.com and find their Ford Vehicle Order Tracking. Or you can plug your VIN into the tracker tool on this forum and see what they can tell you. I will say, once I logged into my ford.com tracker, I can no longer access the tracker on this forum. Maybe it's coincidental, but I'm not sure. I'm curious if anyone else has had this issue. Hope this helps!I have a VIN but can't get any info on my order?
https://fordtracker.tech/I have a VIN but can't get any info on my order?
https://fordtracker.tech/Do you have your order number? That is key to getting your information. On my order summary from my dealer, the number you need is called an Order Code (mine was 4 digits). When you have that, you can go to Ford.com and find their Ford Vehicle Order Tracking. Or you can plug your VIN into the tracker tool on this forum and see what they can tell you. I will say, once I logged into my ford.com tracker, I can no longer access the tracker on this forum. Maybe it's coincidental, but I'm not sure. I'm curious if anyone else has had this issue. Hope this helps!
