FordBroncoLifts
Gold Sponsor
Robby
Las Vegas
2021 bronco sport 2019 ranger Fx4
Just purchased my base model last Tuesday. I quickly designed and installed my own 2” level lift. I installed 245/70/17 bfgoodrich km3 tires. I will be installing some ALPHAequipt wheels this week. Just got the windows tinted yesterday.
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 196F224B-D4C8-4E5C-8EBE-FFB70D8D6E3C
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 4C02B8A3-7827-4E17-9E2D-CA737B34C91E
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods C68CACEF-68CF-447B-B92D-82F24565D13E
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 4F738040-5A3D-4023-884E-455D9790B6F9
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods B33285A5-CA4A-471C-BE73-72F5667B1D71
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 12572293-5620-45A4-B63D-3CE2EBF647B7
March 1, 2021 Update
Added a front light bar and some 4” rigid lights.
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods bbd3f238-a881-4174-9596-2a2fdb245290-jpe
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods d9f8290e-2aea-431a-8f4d-30b8cf946520-jpe
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods cd530be3-fccb-45d0-b0c3-e11c1b5cb4a3-jpe
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods b8faeb0b-99d8-400e-a8f7-2bf2e8dd074c-jpe
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 688fb74d-8a32-4a84-9c15-7d25e5089a79-jpe
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 35be60b5-c779-43d2-9888-2f5ed6dc053d-jpe
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 55667cd4-e301-4595-80b7-c42e9ae8cd71-jpe
retiredguy
Looks great!!
Wyo
Wyoming
@Wyo what you going to do with original wheels(rims) and tires? Just curious is all. Road driving?
Probably nothing. I love the Falken Wildpeaks. They are a great all-around tire. And I actually like the wheels.
Bobaloo
Atlanta
2021 Ford
Bobaloo
Atlanta
2021 Ford
Wow, looks sweet with all that rubber around the standard wheels even! Can you explain how you did your own 2 inch lift and did you have to do that in order to house that much rubber around the rims? Any scraping on the front now on full turns?
Bobby L
Bobby
Seguin, Tx
Ford Bronco Sport, Audi RS5, Ford F-250
Looks great! Did the level kit consist of front & back or just front?
FordBroncoLifts
FordBroncoLifts
Gold Sponsor
Robby
Las Vegas
Just front as of now. The front is actually 3/4” higher then the rear right now. So I might do a 1” lift in the rear.
FordBroncoLifts
FordBroncoLifts
Gold Sponsor
Robby
Las Vegas
That much rubber did fit on stock offset wheels. I had to trim the pinch welds on the firewall to clear at full lock. I designed and fabricated the 2” to achieve the level look and make room for the 30.5”x9.6” tires on stock wheels. I will be installing some aftermarket wheels this week to determine if the 2” is sufficient or if I need to do anther 1/2”.
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods A3A21697-2C3D-4782-A414-84952511D4A3
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 1AC254B0-4319-48A9-BA9A-C1A7DF58FC25
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 63A8752B-B899-4850-B77C-21BF544D4482
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods FCEED103-84D1-489C-8A59-27B3CC1990E0
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods 6F1E738E-20F5-42A1-B2C8-9041866DF05E
Ford Bronco Sport Bronco Base Build: 2" level kit, 30.5" BFG KM3 tires, light bar, 4" Rigid light pods D0911F12-7030-4082-B117-FEA486626D7F
ElBronc
WA
Looks awesome. So, is there any reason my FE with a 1" lift kit from 4WP wouldn't be able to fit this 245/70R17 size tire?
I've wanted the setup like the trail rig concept, but I keep hearing that 245/65R17 is the largest tire I can do even with the 1" lift.
Yet I'm seeing that size put on lower trim level Sports that are an inch lower than mine to start with.
I'm confused ?
FordBroncoLifts
FordBroncoLifts
Gold Sponsor
Robby
Las Vegas
I'm confused ?
I’m interested and curious also. Can’t wait to get my hands on a FE or BL to see what the difference is.
BaseOrBust
2017 Ford Focus
Looks wicked!
