Bronco Badlands 2025 Extra Temperature Gauge
Area 51
Slate, WV
2023 Bronco Sport Badlands-Area 51; 2012 F-150 and now 2025 Badlands
My temp gauge is reading 85 degrees outside temp. My weather station is reading 102 degrees. Is there anyway to calibrate the temp gauge for the 2025 Badlands?
I don’t know of any calibration (maybe there is however) or maybe the outdoor temp sensor is not working correctly - in the ā€˜21 to ā€˜24 that sensor is mounted somewhere below the front bumper (I need to search for its location which I saved)
But the Ford dealership will cover that diagnosis, calibration (if possible), or replacement / repair under warranty
Any reason not to let the dealership fix it?
Area 51
Area 51
Slate, WV
I will contact my dealer. Thank you. I didn't know it was covered under the warranty.
When I find out the response, I will let you all know.
Are you in W VA and it’s 102? That must be pretty bad with the humidity
Last night here was 102 but around 7pm, very nice … rolled the windows down with the AC off
Area 51
Area 51
Slate, WV
Yep, in Mid-Ohio Valley in WV. Last night at 1 a.m. it was 70*, 99% humidity, clear skies, light haze, calm winds. It is now 100* feels like 118*, 57% humidity, no breeze/stagnant air.
Superdave
Dave
Minnesota
2025 Ford Bronco Sport
If you drove in the rain and the temp sensor in the front behind the bumper got wet, it will usually read colder than the outside temperature until it dries off due to cooling effect of evaporation.
NMBroncoSport
PJ
This happened on my '25 4Runner after I had washed it. Haven't seen this in my '26 Badlands Bronco Sport, but here's what AI has to say:
The outside temperature display on the 2025 Ford Bronco Sport works much like the one on your 2025 Toyota 4Runner. It doesn’t measure the air at roof level—it measures the air flowing past a sensor mounted near the front of the vehicle.
How it works
The Bronco Sport has an ambient air temperature sensor (a thermistor) mounted behind the front grille/radiator support area. The sensor changes electrical resistance based on temperature, and the vehicle’s computer converts that into the temperature shown on the instrument cluster.
The system is designed to:
* Measure the temperature of the air flowing over the sensor.
* Filter out rapid changes so the display doesn’t jump around.
* Ignore brief heat spikes from engine heat or pavement.
Because of that filtering, the display often lags behind actual conditions.
Why it might read 85°F when it’s actually 102°F
A 17°F difference is larger than normal, but there are several possible explanations.
1. The sensor was cooled by water (very likely)
This is exactly what happened with your 4Runner after the car wash.
If:
* the Bronco Sport had just been washed,
* driven through sprinklers,
* driven in heavy rain,
* or the sensor got soaked,
evaporation from the water can cool the sensor well below the surrounding air.
For example:
* Air temperature: 102°F
* Wet sensor temperature: 85°F
The display follows the sensor—not the actual air.
As the sensor dries, the reading gradually climbs.
āø»
2. The vehicle had just been parked in a cool garage
If the sensor started at:
* 75–80°F inside a garage
and you immediately drove into 102°F weather, the computer intentionally updates slowly.
It may take:
* 10–20 minutes
* sometimes longer
before it reaches the true temperature.
āø»
3. The sensor is getting unusually cool airflow
If:
* a splash shield is missing,
* air is being directed unusually toward the sensor,
* or the sensor has shifted from its normal mounting,
it can read lower than actual.
āø»
4. A damaged or failing sensor
Thermistors can drift with age or damage.
Symptoms include:
* consistently reading 10–20° low
* readings that never catch up
* sudden jumps in temperature
āø»
5. Loose electrical connection
Corrosion or a partially connected plug can change the resistance the computer sees, resulting in inaccurate readings.
āø»
6. Software smoothing
Ford intentionally averages the temperature to prevent the display from changing every few seconds.
Normally this only accounts for a few degrees—not 17°—unless one of the above factors is also involved.
āø»
What’s considered normal?
Most manufacturers consider these typical:
* ±2–5°F: Completely normal
* 5–10°F: Possible after startup or weather changes
* 15–20°F: Usually indicates water on the sensor, recent garage parking, or a sensor issue
What I’d do
If this only happened once:
* Don’t worry about it.
* Drive for 20–30 minutes at highway speed in dry conditions.
* See whether the display gradually reaches within about 2–5°F of the actual outside temperature.
If it always reads around 85°F when it’s actually near 100°F, then I’d suspect:
1. A wet or improperly mounted sensor.
2. A faulty ambient temperature sensor.
3. A wiring or connector problem.
Area 51
Area 51
Slate, WV
There was absolutely no rain, no puddles, no car washes, no fog, no dew, no dampness and there is only 6,000 original miles on the vehicle. So we can leave out the rain, and all the listings I stated. I believe it was after 12:00 p.m., full sunshine, no winds.
NMBroncoSport
PJ
If it consistently continues to be wrong, dealer time? It's a pretty simple circuit and most of it is software algorithms to translate the thermistor readings into a temperature value to display.
