Anyone else having trouble fueling up?. My 2021 Big Bend will not take fuel into the fuel neck easily. Have to add it very slow
No problems over here at a pumpAnyone else having trouble fueling up?. My 2021 Big Bend will not take fuel into the fuel neck easily. Have to add it very slow
I took it in to my Ford dealer and they are working with the engineers apparently nowI have had this happen three separate times.
Keeps us all posted please.I took it in to my Ford dealer and they are working with the engineers apparently now
Thanks I will try that!What I have found on my Big Bend is that the pump spout doesn't just slide in, that you have to give it an extra push. Feels like there is check valve that you have to push through.
I noticed the same thing when I first pumped gas so every time I pump gas I always give it a little push. No issuesWhat I have found on my Big Bend is that the pump spout doesn't just slide in, that you have to give it an extra push. Feels like there is check valve that you have to push through.
Marky, others here are saying the nozzle just needs a little push to get by the second flap. Yours actually had a problem where technicians are scratching their collective heads with your Sport?I took it in to my Ford dealer and they are working with the engineers apparently now
