notabumblebee
2022 BroncoSport
I'm starting this build journal to keep track of everything I'm doing and maybe give other people some ideas.
Here are my build specs:
2022 Badlands
Area 51
Tow Package
235/65/17 Wildpeak AT3 tires
Ford Bronco Sport Badlands - Overland Build IMG_1009 (2)_LI
The main item I've been working on is a drawer system for the back, the dimensions are 41x26x12. That should give me just enough room to put my recovery boards behind the drawers. The reason I chose this size is because it allows me to fit everything I need in the drawers including larger items like my stove & propane tanks and enough room for my cooler to sit on top.
it's not quite done but some progress pictures:
One side was designed to have a pull out work area and wide enough to fit my camping stove.
Tie down anchors for securing it, I did one on each corner:
I'm currently covering the top with a thin layer of rubber, not sure how much I'll like it but I can always remove and sand.
Next things on my list:
Cover the pull out work area in something fire resistant.
Building in some partitions to organize my camping and biking gear
Assemble and mount a smittybilt overland gen2 RTT (currently sitting in my garage)
notabumblebee
notabumblebee
2022 BroncoSport
Looks great!
Here is mine, it's worked out great.
Ford Bronco Sport Badlands - Overland Build PXL_20211113_120651326-1
Ford Bronco Sport Badlands - Overland Build PXL_20211203_071739985
Ford Bronco Sport Badlands - Overland Build PXL_20211224_225919786
I was watching your build thread with a lot of interest! Turned out fantastic!
What leg did you use at the of the pull out? I'm still debating using a piano hinge to attach a 20x24 extension to my work area. I left a two inch gap for that extension or a expanding leg.
Much nicer than my “camping kitchen” I made 40 years ago. Kept all my crap in it locked up on the picnic table rather than in tubs etc in the tent. Hopefully you will get lots of enjoyment out of it like I did mine.
ctrabbit25
Carlos
Austin, tx
My leg was an after thought I added right before the first trip I used the kitchen and I haven't upgraded it since. It's just a tension rod with a cane foot attached that can be screwed on or removed when packing up, but it works! It stores with the stove.
Ford Bronco Sport Badlands - Overland Build PXL_20220408_054717289
Ford Bronco Sport Badlands - Overland Build PXL_20220408_054725992
I would suggest adding adjustable feet on the side to fix sliding back and forth if you go off roading. I recently added those and it really helps.
Ford Bronco Sport Badlands - Overland Build PXL_20220408_054516882
AndyMac204
Andy
awesome work, well done and well thought out. your rotopax on the 1/4 glass....is it pretty solid? any concerns about glass breaking?
awesome rig.
AndyMac204
Andy
also, you're gonna love the smittybuilt RTT. i'd say prob the best one out there.
ctrabbit25
Carlos
Austin, tx
awesome rig.
Thanks!
Here is a close up of the bracket for the rotopax. It's been on the car for over 6 months and used many times. It's never moved even off-road and it's also easy to take off to use and fill. No concerns it's been great.
Ford Bronco Sport Badlands - Overland Build PXL_20211112_065458875.NIGHT
Ford Bronco Sport Badlands - Overland Build PXL_20211112_065525224
notabumblebee
notabumblebee
2022 BroncoSport
Thanks!
Where did you get the mount? That's exactly what I've been looking for!
ctrabbit25
Carlos
Austin, tx
I technically made it here are the parts
RotopaX RX-TN Toyota and Nissan Truck Plate https://www.amazon.com/dp/B008S9QSJM/ref=cm_sw_r_apan_i_TPHW3FVYJY8M7WYQNCYV?_encoding=UTF8&psc=1
CAMVATE Extended Size C Clamp with 1/4" & 3/8" Mounting Points For Photographic Accessories https://www.amazon.com/dp/B08L4C23LY/ref=cm_sw_r_apan_i_M6W8AR5CRA0EZXVQQYHH?_encoding=UTF8&psc=1
HSTECH (4 Pcs) Black French Fry Suction Cup Feet Compatible with Industrial Commercial French Fry Cutter https://www.amazon.com/dp/B08J42YLTQ/ref=cm_sw_r_apan_i_WMFDJDCZW1X3VCFD4XPR?_encoding=UTF8&psc=1
And some heavy steel L brackets
notabumblebee
notabumblebee
2022 BroncoSport
A couple of updates:
Rubber mat added to the top and finally mounted in the BS.
Ford Bronco Sport Badlands - Overland Build IMG_1067_LI
Work area added to the top of the galley drawer, on a piano hinge.
Ford Bronco Sport Badlands - Overland Build IMG_1068_LI
Propane fuel line installed, eventually I'll get a 5Gal tank but for now the 1lbs will work.
Later this week I'll be mounting my RTT, preparing for a trip this weekend.
notabumblebee
notabumblebee
2022 BroncoSport
Roof top tent has been installed but I'm not very happy with the way I had to mount it. It feels secure but I would prefer the rails to be directly on the metal.
Avoid the OEM cross bars if you want a RTT, I'll be replacing them eventually.
Ford Bronco Sport Badlands - Overland Build 1650383105826
Ford Bronco Sport Badlands - Overland Build 1650383125989
AndyMac204
Andy
Did you have any issues mounting yours? I have a feel the OEM cross bars just suck.
we mounted ours on the Thule Evo Crossbars. no issues mounting. i also cut strips of rubber from an old floor mat to sandwich between the 'u-bolt' and the crossbar. just a lil added protection so it doesn't slip. but it never moved at all. i can't see you having issues.
