Any suggestions out of these 3 tires?
Looks like Discount Tire still offers the OEM Falkens AT3w’s. I know they are not on your list, but I’d buy them again if still available when I need tires.
How do you differentiate a OEM AT3W from a regular AT3W at Discount? I'll need new shoes in the next 10K so I think I will line up another set of OEM if they're still out there.
OP, if you can get the Falkens, you will like them. I am at 41,000 now, and could go to 50k. It's a good mixed use tire.
The FO at the end of the part numbers shows it’s an OEM only tire. The 235/65-17 size is only available in the OEM version of the AT3w.
Iamcanadian
Jason
Ontario Canada
Out of those three, I would definitely say the toyos. Definitely not the go15. Literally one of the worst Tire decisions I've ever made of my life. Garbage Tire with no winter traction. But if you want another really good Tire like everyone's mentioning here would definitely be the falcen wildpeak
dockiwi57
26 BSBL
Check out the Discoverer Road+Trail AT. They rank pretty high with tire rack for noise, rain, etc.
My reading is pushing me towards these. When I make a decision to move from the OEM Continental Cross Contacts, the Coopers are where I'm likely to end up. Do you have personal experience with them?
JPtapt
Not yet, but all my research says these are the ones to go with. 235/65r17s on method 502 rally wheels. Just waiting on my tax refund. We are moving down to sw Florida and they should be fine in the preserves and the Everglades backroads. And good in the summer heat and thunderstorms in the city.
Oh, huh. I knew the Ford Falken tires have less sidewall layers than a typical A/T Falken tire. I was always fine with that because I don't go on big rocks. A long time ago, I took this post from Falken to mean there were OEM and regular equipment versions out there with standard sidewalls.
https://www.broncosportforum.com/forum/threads/factory-oem-tires-vs-wildpeak-a-t-trails-vs-at3ws-big-bend.4462/post-86585
It’s only the 235/65-17 size that’s specifically designed to meet the Ford specifications. A 245/65-17 would be the standard ATW3
incavulator
I didn't think Falken made the AT3W in 245/65/17. At least I couldn't find any when I tried. If you want that size you had to choose the AT4W.
They do not make the AT3W anymore but there are still some of the 235/65-17 available. As for the the 245/65-17, it doesnt appear those are still in stock anywhere.
Ford Bronco Sport Any suggestions out of these 3 tires? IMG_1430
Iamcanadian
Jason
Ontario Canada
The falken wildpeaks that were made for Ford don't have any last sidewall plies than the regular version. They all have only two sidewall plies. The difference is in the number of physical plies in the tread. And not only applies if the tire was an extra load or not. I do believe the one for Ford is a standard load the equivalent Tire that wasn't made for Ford is an extra load so it would have one more tread ply.
Jump to the new at4w and they all have a three-ply sidewall.
Kraken1
Larry
Ontario
Toyo Open Country, I have already ordered them.
I've heard nothing but good things about them.
Mt rigged
Brian
Mt
I put the Geo’s on mine, 255/65/17, with a lift.
it’s a lighter tire and has handled great in the snow. Mileage came down about 9% overall, but the look and ride is worth it.
No apreciable road noise so that’s a win.
Mt rigged
Brian
Mt
I have also been looking at Patagonia’s. They look to be similar to Geo’s but with a more aggressive style. Might be going to those next.
