50k Mile check in
OrangeCrush
Pat
Iowa
2022 BSOB,2016 Flex SEL,1996 F150 XL SB
Our 22 OuterBanks is at 37K . Counting the one it came with we are on our 4th water pump. Did all the recalls and waiting on the battery recall ,although the battery has never been an issue,knock on wood. Otherwise we like it as out daily driver.
muteman
Will
michigan
Bronco Sport, Bronco Everglades, Willys JL
I'm over 91k on 21. The usual wear parts, 3 sets if tires. I'm sure something will go soon.
21Broncosaurus
Ish
SoCal
21 Bronco Sport
2021 1.5L 81k+ miles. Nothing to really complain about so far. Few recalls done. Early on I had park brake cable replaced due to rattling. Around 50-60k miles catalytic converter cracked. Everything replaced under warranty. I do add a bit of coolant once a year but water pump hasn’t failed me yet. Overall I’d say it’s been a fairly good vehicle.
V8 Yankee
Harold
Miami
21 Bronco Sport
2021, 65K: I purchased new in Jan 22. At 35K I had the RDU and left rear axle replaced due to pronounced shuttering. At 55K I had the water pump replaced, coolant system flushed and new coolant. Thankfully both major works were covered by the warranty. At around 35K I replaced the battery and tires. The original Michelin's didn't wear as good as I expected. I replaced those with Continentals which seem to be wearing much better, from the looks of it I will get 50 to 60K out of those. Other minor things is the rear brake groan is still there, even after the new kit was installed. The funky injector fix (drain hose) was installed last year. I also had the software updates, I believe two of those since I owned it. I just received a notice on a new recall for the front seat belt latch. No problems with it but I won't wait for a problem to develop, I'll schedule that soon. I have to say I really like the BS overall but the reliability is questionable for the long term. By that I mean over 100K.
laurent1784
Laurentino
Panama City, Panama
Bronco Sport Big Bend
Mine is at 23k km or about 18kmiles. Had the battery replaced due to initial failure (not AGM from factory) at 10k miles, software update for injector issue and drain hose installed at 8kmiles. Had the RDU shudder issue, so fluid and RDU actuator replaced under warranty at 12kmiles. Other than that, no issues though. Still running great down here in the tropics with 85% humidity and average temperature of 31 degrees Celsius or 88 Fahrenheit. Only thing that sometimes happen is on eco mode and low load there is a rattle in the engine but I guess it is the dreaded cylinder deactivation.
