derickveliz
Derick
Massachusetts
2022 Ford Bronco Sport Badlands
I definitely subscribe to the larger sidewall “side” of life but honestly, after many years of wheeling, the difference of 10mm or 3/8’s of an inch in width or 12mm or 1/2 in of additional clearance isn’t going to change where this can or cannot go by much (IMO). When people are now wheeling with 37’s or 40’s, going from 29 to 30 isn’t changing things significantly.
Just changing to a more aggressive tread and squarer corner/edge gives it a much better look.
In my case I like how chubby the 245-65-17 look on OEM wheels ?
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s 6E60B230-8CED-40E2-962B-5D7821387053
I agree, they look really good. I think because of the sharper corner compared to mine.
Is your spare a “chubby” tire as well? If so, does it fit without modification? My 235/65-17 just seems to fit without modifications.
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s 82B2B196-61C4-4B99-91BE-5C9AB6A4D257
brianloch1974
Brian
Butler, PA-USA
2022 Bronco Sport Big Bend
So I pulled the trigger and joined the truck tire gang. Issue I was having was did I want to play it safe and find 245/65 or go tall and skinny and attempt 235/70. Well pretty happy with the results.
They clear! Even at full lock. But just barely. We are talking by say a quarter inch at full lock.
I pulled the trigger on the Firestones of all the available choices (and there are not many in this size) bc they were rated excellent in the mountains and damn it the Badlands needs better than fake ATs. Also I paid $155 per tire the list of $218. And a $60 rebate.
All said and done gained a inch lift from the bigger tires and it looks bad ass with the extra sidewall.
Any questions let me know. PSA this is a Badlands. Pretty damn sure these are not going on the lower suspension models unlifted.
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s IMG_20220609_145800396_HDR
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s IMG_20220609_145933393_HDR
I got 235/60/18 to fit my BB. I love it!
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s IMG_8128
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s IMG_8129
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s IMG_8130
Moltenburn
Moltenburn
Denver
2022 BS BL w prem, 360, shelf. VW Arteon
So about 1 month now on the new bigger tires. Zero regrets. Truck drives like a tank. And no rubbing even off road.
Henry_61
Enrico
Alexandria, VA
Good job! Now your Bronco looks really beautiful! I'm thinking to lift my car and put 235/70/17 tires too!
So it has been a time since you went with the 235/70/17 , so would you do it again ? Leaning towards 235/70/17 cooper at 30 inch also any regrets , I am a pavement driver no off road . Looking for your experiences with your set -up . Thanks for your thoughts. Jim Pittsburgh Pa
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s 7599B959-BE68-4A54-9143-27BC86B1F404
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s DB4E98A8-C9B0-4D1A-B0F2-C35039509C4B
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s FF5C3829-9ADE-464D-8B3A-6710ADC7374E
Bronclahoma
Oklahoma
The best thing you can do to a BS for offroad performance is put
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s 52508783624_eebca57d96_o (1)
on a good set of tires. I went the KO2 245/65/17 with my Badlands. I've had it on trails in CO and Northern NM for weeks at a time never felt it rub. They are noisier, though. A 245 Wildpeak would probably be quieter, but I wanted the grip of the KO2's.
Moltenburn
Moltenburn
Denver
Nope no issues at all. Still no rubbing even when Off road. Road noise way down. If the truck is awesome and snow.
Thanks , now to track down a set .
Moltenburn
Moltenburn
Denver
Worth the money. These Firestones or the mentioned Coopers are both mint. I would totally do it again.
Moltenburn
Moltenburn
Denver
And it will add an inch just tire lift.
Reactions: Jrl
Can you really see the 1 inch difference.
Definitely see the difference in ride and physical appearance. Mine is a First Edition model pretty much a badlands model, I have been beside many standard Bronco and you can see a big difference because of the factory lift and the 70 series tire height , over a 2.5 difference. All good no rub at all.
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s IMG_1878
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s IMG_5525
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s IMG_0819
Ford Bronco Sport 235/70/R17 Tires Fit!  On a Badlands but just barely. Firestone Destination AT2s IMG_0813
