2025 BS 17” Ford Performance Wheel Kit
kevinrhaas
2025 BS
Hi all, new 2025 BS owner, looking at 17” wheel kit M1007KS17BSB for BS 2021+, which Ford says is NOT compatible with the 2025 compared to single wheel M1007S17BSB which Ford says IS compatible with 2025’s.
AI says this is only a TPMS sensor difference. True? Can the kit be ordered and have the installers swap out the sensors from my existing 2025 wheels? Or do I have to wait until the single 2025 wheels are back in stock? Thanks in advance!
Whpony96
Scott
Nampa, Idaho
They are out of stock and have been for a long time now. Ford might not be bringing that style back, and once stock is gone it's gone. You might have a lot more luck looking on E-Bay.
TheX
Randy
Austin TX
www.netwerkin.com
the TPMS sensors for the 2025 Ford Bronco Sport are different from prior years (2021-2024); the 2025 models switched to a 433 MHz frequency, while earlier years used 315 MHz, making them incompatible for wheel swaps without changing sensors. You'll need specific 433 MHz sensors for a 2025 Bronco Sport if you're buying new ones or transferring from an older model.
Key Difference:
  • 2021-2024 Bronco Sport: Uses 315 MHz TPMS sensors.
  • 2025 Bronco Sport: Uses 433 MHz TPMS sensors.
Why This Matters:
If you put wheels with older 315 MHz sensors on a 2025 model, they won't work, and vice versa. When buying replacement sensors or swapping wheels, ensure they match the 433 MHz frequency for the 2025 model year.
