2025 1.5L oil capacity?
desrever
2025 Bronco Sport Heritage
Anyone change their oil on a 2025 and can confirm the oil capacity is 5.0qt? I looked through the manuals online and it looks like it's been 6.6qt and 5w20 since 2022. 2025 says 5.0qt and 0w20.
2025 vehicles are equipped with the new MPC engines. These are redesigned engines. Which engine do you have, 1.5L or 2.0L?
The first gen Sports ('21-'24) got a mid-build change and the regular oil pan was replaced with a plastic pan. The plastic pan engines have a higher capacity. To compound the issue, I think some early versions of the manuals stated the wrong capacity.
As said previously, the 2025 engine is a different design and only comes in one capacity. So I think you can trust the 5qts if that is what the guide says. If you're changing it, I would go ahead and get a 5qt jug and an extra 1qt. It won't hurt to have a quart on hand to top it off down the road. Check how much you drain and the dipstick when you refill. Run it to fill the filter and gallery and recheck it. That will verify the right amount.
desrever
2025 vehicles are equipped with the new MPC engines. These are a redesigned engine. Which engine do you have, 1.5L or 2.0L?
1.5L
Right, a quick initial google search had a lot of discrepancies so I had to look at the previous years manuals to compare. Do you happen to know if it’s still a plastic pan? I will verify with the drain and check the levels when the time comes. It’s the wife’s car that was purchased last week and it has about 200 miles on it so I have a ways to go. It got new tires today and I’m deciding on a lift kit soon. I just started looking into the maintenance schedule out of curiosity to get an idea. I also have a decent amount of oil for my other cars and was curious if I was dipping into that stash.
sennaspirit
david
I changed mine last week (for the first time) and after a frustrating search for the proper capacity, I went to my dealer and they confirmed it was 5 qts. I have a 2025 built in Jan of this year. I'm now searching for the air filter since the autozone book has a completely different air filter listed (STP) than the one thats in the car.
Garth
Garth
Ontario
I don’t have a link, but I read an article that talked about 0 20 oil being used to meet epa standards in the United States and 5 30 oil used everywhere else. I think if they called for 0 20 oil I would check what they use for my engine in other countries and go for the thicker stuff.
Stircrazy
BC, Canada
2023 Bronco sport
6.6 quarts (6.25L) for models built on or after August 3, 2022 (plastic pan)
With metal oil pan (1.5L EcoBoost) 5.3 quarts (5.0 L)
for 2025 it is listed in the owners manual as 5.0 qt (4.7 L) like you said and 0-20w
wireman
Murrieta
2025 2.0L is 6.1 qts. and 5w-30 recommended. Online manual on the attachment below.
My 2025 owners manual shows 6.1 qts. but says 0w-20 even though the oil cap on the engine is marked 5w-30.
Is it that hard for Ford to get these important specs figured out?
Ford Bronco Sport 2025 1.5L oil capacity? OIL RECOMMENDATION ON LINE MANUAL  5W-30
desrever
Will look into it. It does look like 0w20 was only the rec in previous years for cold climates which doesn’t apply to me. I will probably do a couple oil analysis to see how this car does as well.
Shadow Bronc
ELF
Washington
All I know is I have a 2024 BSBL, it states: (usa) 5.5 quarts 5W30 recommended.
Garth
Garth
Ontario
From the 2025 Bronco Sport HTML manual online:
Engine Oil - Engine Oil Capacity and Specification - 1.5L EcoBoost™
Use oil that meets the defined specification and viscosity grade.
If you do not use oil that meets the defined specification and viscosity grade, it could result in:
  • Component damage that your vehicle warranty does not cover.
  • Longer engine cranking periods.
  • Increased emission levels.
  • Reduced vehicle performance.
  • Reduced fuel economy.
An oil that displays this symbol conforms to current engine, emission system and fuel economy performance standards of ILSAC.
We recommend Motorcraft motor oil for your vehicle. If Motorcraft oil is not available, use motor oils of the recommended viscosity grade that display the API Certification Mark for gasoline engines.
Do not use supplemental engine oil additives because they are unnecessary and could lead to engine damage that your vehicle warranty does not cover.
Capacities
Variant Including the Oil Filter
All.​
5.0 qt (4.7 L)
Materials
NameSpecification
Motorcraft® SAE 0W-20 Motor Oil
XO-0W20-QFS
WSS-M2C962-A1
wireman
Murrieta
Curious, those of you who have a 2025 with the 1.5L, what weight is shown on your oil fill cap?
My 2025 BL with the 2.0L has 5W-30 marked even though the manual says 0W-20 as I explained before.
BobbyTony
Bob
Soon: 2025 BS OBX Now: 2019 Edge Titanium, 2014 F150 XTR, 2006 mustang GT
Just did my first oil change today on our '25 1.5L (@2k km), fill cap says 0w20 and the 5qt oil jug i filled it with was just so full I bet the factory put 5L in rather than 5qt, lol.
sennaspirit
david
My 2025 Heritage Ed. 1.5L is 0W-20 (5qts)
