2023 BS Badlands “Shift System Fault” message
winn70
Nth Iowa
2023 Ford
47,000 miles on our 23’ BS Badlands and a “Shift System Fault” message came up 3 times after about 140 into a 165
Mile trip for my wife this week. “Service
immediately “ also popped up. I immediately looked at my Alerts and it didn’t show up! I called our service dept. and he could not locate any alerts. It was and still is running fine. It goes in Friday to be checked out. One thing after another with this vehicle. Shocks, water-pumps, sway bar, fuel injector recall (still not addresses). We also get “Hillside Braking failure” alert weekly.
You indicate you have a 2023 Bronco Sport Badlands. This has a 2.0L engine.
There is no known water pump issue with this engine.
There is no known fuel injector issue with this engine.
Are you sure you have a 23 Badlands?
winn70
Nth Iowa
2023 Ford
1.5 engine and all of the above are correct.
Yes, 23’ and all issues listed are correct.
winn70
Nth Iowa
2023 Ford
Engine Specifications
ENGINE TYPEHORSEPOWERTORQUETRANSMISSION
1.5L EcoBoost I3181 hp190 lb-ft8-speed automatic
2.0L EcoBoost I4250 hp277 lb-ft8-speed automatic
You are stating that you have these issues? You have us confused.
Hey @winn70 what is the age in months of your Battery on the 23’ Big Bend and can you look at the battery to see if it says AGM
You say you have issues with the front stabilizer bar or the links to this? Do you happen to have a lift kit installed?
winn70
Nth Iowa
2023 Ford
No lift kit. Sway bar was replaced..
We bought it new in August 2023. I will take a look. I’ve read a loose battery cable or weak battery can cause those messages.
First time I have ever heard of a front or rear stabilizer bar needing to be replaced.
Ford will replace any cracked or leaking fuel injectors at no cost. The issue is with an acceptable warning system to meet Federal approval.
