- First Name
- PHILLIP
- Joined
- Sep 23, 2024
- Threads
- 1
- Messages
- 6
- Reaction score
- 2
- Location
- CHATTANOOGA
- Vehicle(s)
- 2021 FORD BRONCO SPORT
LET ME START OFF SAYING, I'M A HUGE FORD GUY! OTHER THAN 2 VEHICLES, THAT I DIDN'T KEEP VERY LONG, HAVE ALWAYS PURCHASED AND DRIVEN FORDS. MY SON AND HIS WIFE PURCHASED A 2021 FORD BRONCO SPORT, I GUES THAT IS CONSIDERED A BASE MODEL? USED FROM A NORMALLY REPUTABLE DEALERSHIP HERE IN CHATTANOOGA. THE BRONCO HAD 80,000 MILES ON IT WHEN THEY PURCHASED IT 9 OR 10 MONTHS AGO. IT HAS BEEN PREFORMING FINE AND MY SON HAS KEPT UP WITH THE TYPICAL MAINTAINANCE ON IT, OIL CHANGES, ETC. A MONTH AGO THEY NOTICED THE BRONCO SHIFTING ROUGH AND IT JUST GOT WORSE UNTIL THE VEHICLE WOULD NO LONGER GO IN REVERSE WITH THE SELECTOR AND WAS SHIFTING FROM FIRST DIRECTLY INTO A HIGH OR O.D. GEAR PROVIDING ABSOLUTLY NO ACCELERATION. TOOK THE BRONCO TO MY FORD DEALERSHIP TO CHECK IT OUT, THEY REPORTED BACK THE TRANSMISSION HAD FAILED AND WOULD NEED REPLACED TO THE TUNE OF $9800.00 ROUGHLY. THEY DID NOT, UNFORTUNATLY PURCHASE ANY KIND OF WARRANTY ON IT WHEN THEY BOUGHT IT. THE DEALERSHIP SAID THE FLUID HAD A SIGNIFICANT AMOUNT OF METAL DEBRIS IN IT AND THEY WOULD NOT KNOW THE EXTENT OF THE DAMAGE UNTIL THEY PULLED IT AND DONE AN INSPECTION. ENDED UP TAKING IT TO A VERY REPUTABLE TRANSMISSION SHOP HERE IN TOWN THAT I AM VERY FAMILIAR WITH BECAUSE THEY SAID THEY COULD DO IT FOR A LITTLE LESS. ENDED UP REBUILDING THE ENTIRE TRANSMISSION. IT IS DRIVING GREAT NOW. $10,000.00 LATER. THE TECH AND OWNER THERE SAID AS HE WAS TEST DRIVING THE BRONCO FOR SEVERAL DAYS, WITH IT IN, I DONT KNOW IF IT IS 4WD HIGH OR AWD HIGH, NOT FAMILIAR WITH THE BRONCO, BUT THE SETTING THAT IT WOULD BE USED IN TO DRIVE ON THE NORMAL PAVEMENT, AS HE CUTS THE WHEEL SHARPLY, HE COULD FEEL THE SNAPPING OF THE REAR-END MUCH LIKE HAVING A 4WD TRUCK IN 4 HIGH OR 4 LOW ON DRY PAVEMENT. I HAD A FORD F-150 THAT WAS 4WD AND IT WOULD DO THAT IN 4WD WHEN IT WAS ON DRY PAVEMENT. HIS AND MY QUESTION, IS THIS NORMAL? IS THAT A RESULT OF THE AWD ON THE BRONCO? HIS CONCERN IS THAT SOMETHING IS NOT DISENGAGING AND THAT MAY HAVE BEEN OR COULD CAUSE AGAIN THE TRANSMISSION FAILURE. SORRY THIS IS SO LONG BUT I WAS HOPING SOME OF YOU OTHER BRONCO OWNERS WOULD KNOW HOW TO ANSWER THIS. DON'T WANT TO RUIN THE TRANSMISSION AGAIN IF THERE IS STILL A PROBLEM.
thanks for reading!
thanks for reading!
