- First Name
- Tim
- Joined
- Mar 21, 2021
- Threads
- 0
- Messages
- 8
- Reaction score
- 9
- Location
- Palm Coast
- Vehicle(s)
- 2021 Ford Bronco Sport
What size are the mud terrain tires?
32x10x17What size are the mud terrain tires?
Sorry to say but it’s only a 1/2” lift suspension. The other 1/2” is from the tires. My kit doesn’t void factory warranty and has a lifetime warranty on my parts.I would play it safe stick with the Ford lift.I don’t know what they used on my first edition but it came from factory with a 1 inch and it will be under warranty for a number of years to come.
What size tires do you plan to run?I ordered the 1 1/4” for my FE. I’ll post pictures once I get it installed. Can’t wait!
You get one inch extra clearance over a base model but not a 1 inch lift. Part of it comes from tires and the other part from the rear knuckles I believe.I would play it safe stick with the Ford lift.I don’t know what they used on my first edition but it came from factory with a 1 inch and it will be under warranty for a number of years to come.
Rear knuckles? That is false. It’s all in the spring rate. The BL and FE have a 50lb heavier spring front and rear.You get one inch extra clearance over a base model but not a 1 inch lift. Part of it comes from tires and the other part from the rear knuckles I believe.
I’m thinking 245/65/17 KO2sWhat size tires do you plan to run?
That’s a perfect size. ??I’m thinking 245/65/17 KO2s
I am looking into lifting my bronco. This is exactly how i want it to look! What is the lift size on this? 2"? and What size tires and wheels are those?
What model do you have? My 2” fits base model, big bend, and Outerbanks. These tires are 255/75/17 (32x10x17)I am looking into lifting my bronco. This is exactly how i want it to look! What is the lift size on this? 2"? and What size tires and wheels are those?
Factory Warranty remaining for the 2" applies to those in Canada as well? Same goes for lifetime on the parts? Looking to lift OB 2" and keep warranty.What model do you have? My 2” fits base model, big bend, and Outerbanks. These tires are 255/75/17 (32x10x17)
Yes warranty applies to Canadians as well. Lifetime on parts also.Factory Warranty remaining for the 2" applies to those in Canada as well? Same goes for lifetime on the parts? Looking to lift OB 2" and keep warranty.
I am interested, but also curious how you've confirmed that any lift kit could be installed workout voiding any part of the warrantySorry to say but it’s only a 1/2” lift suspension. The other 1/2” is from the tires. My kit doesn’t void factory warranty and has a lifetime warranty on my parts.
