Transmission issues - any suggestions?
AronForthofer
Front Royal, VA
2022 Ford Bronco Sport Outer Banks
So I started having issues with my 2022 Bronco Sport OB, after only having it for 10K miles (91K total).
• Transmission takes time to shift into reverse (R light on dial blinks and then it jolts into gear).
• When slowing down in Normal drive mode, it has a large jolt when it reaches 25 mph. In Sport mode, that jolt is at 45mph.
• Engine luggs at 1200 or less RPM (Normal drive mode) when driving through parking lots or at low speed in town. I have to drive in Sport mode in town to prevent this.
• It seems the TCM was updated 6 months ago (around 10K miles) before I bought it, according to the Carfax. Could this be the issue? Does it have a new update? This is the only "unresolved" recall.
There's an open Customer Satisfaction Program titled "Transmission Control Assembly Reimbursement." Do I need to replace the TCA and will I get reimbursed for it? Do I just need a transmission flush (it has never had one). Am I low on transmission fluid?
Very disappointing, as it was my first car purchase and I've only had it for 2 months (yes I've driven it a lot).
Has anyone else had these problems? And what do y'all recommend?
thomasm23
Los Angeles Metro
When driving on the freeway at 65 mph with the cruise control set, does the tachometer needle bounce 100 rpm every second?
AronForthofer
Front Royal, VA
Update: I took it to the dealer for a separate reason, and they updated the TCM. It took a few times, but now the reversing issue has disappeared (for now). Still has a jolt when slowing down, but less.
To answer a previous question, yes sometimes the RPM will slightly bounce while cruising on the highway. No noticeable effects in terms of feel though.
I know it's about time for a transmission flush, will this change anything? If so, the vehicle does also apply for the TCA reimbursement. Which should I do first?
