Bronco ForScan Thread
PPR_Ricky
Ricardo
Puerto Rico
Does someone know what is the biggest MM I can put on the tire size? Now I have 265/70/17 “that’s 2520mm circumference” and got a message saying that the number is not supported and now I don’t have hill assist,goat modes,cruise control,etc.
I don’t know the largest value that fits in that FORScan parameter… but I’m surprised that tire size fits without runbing at full lock/articulation.. congrats!!
Ford Bronco Sport Bronco ForScan Thread IMG_9869
A Bronco Sport owner has suggested the Bronco Sport is very similar to the Maverick as far as FORScan goes, so a good spreadsheet for the Maverick would likely work:
WARNING: The Ford Maverick FORScan Spreadsheet items have not been tested on a Bronco Sport - YMMV!
Be sure to backup your FORScan as-built configuration in case you need to restore to your backup.
See SSM 51055 Adding/Removing Features Using Programmable Parameters Due To Vehicle Modifications including the statement “Adding/removing accessories and/or programming vehicle features is not warrantable.” .. in post #266 here: https://www.broncosportforum.com/forum/threads/bronco-forscan-thread.844/post-177535
ULTIMATE FORSCAN Ford Maverick Spreadsheet (MASTERLIST)
https://www.mavericktruckclub.com/ultimate-forscan-ford-maverick-spreadsheet-masterlist-?/
Maverick Spreadsheet Link:
(See above link)
FORSCAN TUTORIAL MADE BY THE LEGEND HIMSELF MR. LIVNITUP, IT GOES OVER EVERYTHING INCLUDING BACKING UP YOUR DATA AND ORIGINAL CODINGS:
https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
FORScan 101 - Step-by-Step How to Start Guide
https://www.mavericktruckclub.com/forum/threads/forscan-101-step-by-step-how-to-start-guide.7406/
FORScan uses ABT format to store module configurations. This link provides the differences between the Ford AB (as-built) format and the FORScan ABT format:
https://forscan.org/forum/viewtopic.php?f=16&t=10099
Both store the same data, just in a different format.
Use the "Save All" button. FORScan can restore from AB or ABT format, but only saves to ABT format.
This program can compare and convert as-built files: (this might be a broken link)
https://www.compulsivecode.com/Project_AsBuiltCompare.aspic
2015 - 2022 Ford BMS Change Battery Reset Manually With No Computer - Auto Start Stop Disable
Posted March 1, 2025 by @elvisimprsntr
BACKGROUND
“Forscan 2.3.65 has been updated to support '25 model year vehicles, including the BS.
I was able to permanently disable A.S.S. using Forscan. No errors or warnings on divers display.
Confirmed it is PSCM PID 730-03-01, but Forscan provides an easy to find text description and drop down. Took less than 5 minutes.
No expensive third party wiring solutions required, which may void your warranty.”
https://www.broncosportforum.com/forum/threads/auto-start-stop-technique.9816/post-225952
Ford Bronco Sport Bronco ForScan Thread IMG_3831
Jbfletchr
Bryan
Chino, Ca
2025 Ford Bronco Sport Black Diamond
I can confirm this about the 2025s. It did take them 24 hours to add my 2025 Bronco Sport Big Bend Black Diamond before I could connect it, but it seems to work now. I was able to turn off Start Stop and add traffic sign recognition to the dash. I couldn’t find GOAT modes to activate though. I know on the Maverick forecan it’s under ABS. That doesn’t show up on the Forscan for the Bronco Sport.
acomeaux33
Aaron
Louisiana
Im trying to figure out how to keep the DRL on when the blinker is in use. Also I added Raptor grill lights that are powered by the head lights. I want them to be on with the DRL. If I set DLR with park lights and take power from park light this shou
Winds of Change
Chicagoland
Somebody with forscan might be able.to
2025 Badlands Sasquatch
All ready to go, and find out I need the extended license to make changes. Not sure how I missed that. But hey, my workstation's up and ready! The cart is also perfect for wheeling over to the laser and 3D printer, so there's that.
All done, ASS disabled. Not that it makes much difference in Phoenix most of the year as it rarely does its thing. That makes it worse, IMO, because it's always a surprise when it "engages". Same thing with my last car.
hefler
Global
Bronco Sport 2023
Hey folks,
I was able to activeted the Mirror fold and the reverse mirror down. But is not working.
I can see the configuration completed (in ForScan and in my car BS 2023) but the mirror is not folding or mirror down
Anyone faced the same issue?
cprcubed
Parker, TX
As far as I know, our mirrors don't have the hardware for those capabilities. Cheers!
You are correct, the BS does not have power folding mirrors.
The confusion stemmed from Ford’s mistaken inclusion of that in the configurator for the ‘25’s at certain trim levels or packages.
hefler
Global
Bronco Sport 2023
The version I have in Brazil it does, but it is a button that you press to fold mirrors (see the photo. top button at the left)
Ford Bronco Sport Bronco ForScan Thread Screenshot 2025-08-11 at 10.19.16
so, the module to do this there,
