I’ll be trying the speaker change tomorrow and reporting back if it improves the audio any further. I am just happy to finally be able to enjoy the money I dumped into new speakers lol
I think you posted to the wrong topic. This topic is about using Forscan to modify the vehicle software. I believe the information you seek is in your Owner's Manual. Check out the section on "Connected Vehicle."I get this message everytime I start my Bronco Sport..."Vehicle Data (e.g. dianostic) Collection Active see settings to adjust and for info".
Does anyone know where to go and steps i need to go to fix this so it will not come up on screen again. I go to settings and from there i have no idea where to go.
Glad it worked. I plan on doing mine tonight.So those definitely did help! I noticed a HUGE difference with the flat EQ, but the rear speakers were missing some upper range. With the modifications noted a few posts above, the rears are performing as full range. Now instead of running around at 18 volume on the highway I can comfortably listen at 12 with better audio.
I might try the same. I grabbed Focal 165AC speakers so I have a tweeter in each door and the dash. The post I linked below from Bronco6G another member used an external DSP to map the head unit response to the external DSP which was where I was not happy with the idea that the rear speakers were rolling off bass so sharply.Changed mine just now. Definitely a noticeable difference. I actually didn't care for the EQ change though. It definitely made a difference in volume, but I thought it sounded a bit more distorted. My guess is this is because of the additional tweeters I have in the front(I left the stock tweeters in place for now). I reverted the EQ back to 01 for now.
I don't see a difference between the two?I think this one is better, been using it for the last 6 months with no issues. The benefit s that it doesn't cancel your ODB2 connector, so you don't have to take it off when going for a service. Super simple to install,
https://www.4dtech.com/ford-bronco-sport-21-23-start-stop-eliminator/
Is that just for Ford vehicles? I only ask because my Chevy and Nissan cars only has one touch on driver side, but was able to put all windows down with remote.Global window open is enabled by default on cars that are capable. You must have one-touch switches on all windows to enable global window open.
Unknown.Is that just for Ford vehicles? I only ask because my Chevy and Nissan cars only has one touch on driver side, but was able to put all windows down with remote.
So if it doesn’t do it now, then I’m just wasting my timeUnknown.
