Rodrigo_V_U
Rodrigo
Curitiba - Brazil
Ford Bronco Sport Wildtrak
But it does depend on engine power. It's power that's otherwise wasted out the tailpipe, but it's power nonetheless. It's the same kind of energy that powers a turbine engine. It was genius to realize the energy wasted out the exhaust system could be used to power a compressor.
Which is the very definition of a non-passive device.
In some Heavy trucks From Volvo and Scania, they have a system named "turbo compound".
these trucks have "two turbines" in the exhaust .... The first is connected to the compressor (regular turbo) ... after that, there is a second one, that is connected to some reduction gears and sends power directly to the crackshaft ..... A way to use the thermal energy in the exhaust gas until its limit!!!
One other consideration I like to do is that the turbo is nothing more than a thermal machine that uses another thermal machine (the engine) as its combustion chamber to provide power, hehehe
Dmbleist
Dan
Pennsylvania, USA
Installing OEM mud flaps today.
Ford Bronco Sport What did you do TO your Bronco Sport today? Resized_20230216_093743
Do you have an update about how this went? Looking to make this my next MOD and will most likely be installing myself (with help, if it would be easier for two people). TIA
sinbuster007
Brian
Hagerstown, MD
2 SUV's, 2 Mustangs
I added a set of retro Satin Black bronco sport emblem to my wife's badlands today
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230314_111213
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230314_111126
details where to buy? install? stick-on or rivet?
emaier
eric
ca
2022 bronco sport
I bought them from dennis-carpenter.com. They were a rivet install but I did not want to drill a hole so I cut the posts off and then filled the back in with epoxy. Once it dried I sanded it flat and cut out a flat sheet of 3M automotive tape to match the emblem.
You should be able to get these from Ford now as they are making them for the Heritage Unlimited Sport.
emaier
eric
ca
2022 bronco sport
Correct you can get the heritage emblems now but there's a difference between the 1966 style and the 2023 heritage style. The new ones are plastic chrome and smaller.
Mrmike
Syracuse, New York 13219
Installed the hood insulation that Ford left off my '23 OBX. The correct part # is M1PZ-16738-B 1X. The cost at my dealer was $202.42. It only took 3 days to get. Perfect fit with attaching clips with it. Simple 10 minute DIY project.
Ford Bronco Sport What did you do TO your Bronco Sport today? 100_6559
Jasonj7858
Jason
NC
21 Bronco Sport Big Bend..22 Bronco Sport Badlands
Installed 245/70 17 VENOM TERRA HUNTER X/T tires on my 22 BADLANDS.....and 235/ 65 18 FALKEN WILD PEAK A/T W3...on the wifes 21 BIGBEND today...and new lugnuts without the crappy chrome caps...
No rubbing on the BADLANDS already installed 1 inch adapters....but extremely close..
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230317_122114
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230317_122059
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230317_121955
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230317_122003
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230317_121921
Question if you would , is your badlands lifted or stock lift ?I just installed 235/70/17 on my first edition badlands no lift and you are very right when you say close I have had them on for 5 days and no rub at all , somewhere between 3/8 to 1/2 inch clearance on the front tire front and back . My tires are Goodyear wranglers 235/70/17 thanks
Ford Bronco Sport What did you do TO your Bronco Sport today? 60CE8EA9-1886-4900-8CCB-DA00855B149B
Ford Bronco Sport What did you do TO your Bronco Sport today? BEE2EEEB-8D1E-45B1-98E7-1EA0037062AC
Ford Bronco Sport What did you do TO your Bronco Sport today? DBA47BA0-2A44-43AB-88D0-124740630151
Ford Bronco Sport What did you do TO your Bronco Sport today? 4AFEBC1D-321E-43B9-B4D1-473D7EC0A657
davidb1841
Bruce
NC
Where is everyone getting the BRONCO fender badge......I really like it....and your awesome tires too!
