- Joined
- Jan 4, 2022
- Threads
- 14
- Messages
- 453
- Reaction score
- 672
- Location
- Los Angeles
- Vehicle(s)
- '22 BS BL
Great info! thanks! I see you also tried the Focal. I didn't realized they don't have standard measuring for sensitivity. I didn't find any info on that.You can unplug the dash tweeters. The oem doesn’t have a capacitor, they are daisy chained. The two ways and the dash tweeters will still work if you just plug and play. I left the dash tweeters hooked up since the oem setup is very front biased and vocally soft. I needed volume and clarity with a better soundstage. The oem tweeters are are also 8ohm while everything else is 4ohm. You have to watch some of the sensitivity ratings since some are measured 1w/1m vs 2.83v/1m. 4 ohm at 1w/1m is more efficient than 4 ohm at 2.83v/1m. So the focal and the PB work out to about the same sensitivity since the way they are measured.
I found the vocals too bright with not enough mid bass. Bass would buzz. They’re also 60hz whereas the PB are 70hz. They didn’t sound as good overall compared to the PB.
if they are "daisy chained" in series, that is adding a lot of resistance.
OEM B&O certainly is not exactly B&O's best parts catalog. My Audi's B&O sounds outstanding...so that part I was disappointed....but the upgrade is better than other stock radios. Perhaps that bar is pretty low.
